TwinTurbo.NET: Nissan 300ZX forum - Re: Speed sensor replacement
Subject Re: Speed sensor replacement
Posted by Neflyte on August 24, 2008 at 9:46 AM
  This message has been viewed 1179 times.
In Reply To Speed sensor replacement posted by Adrian (Dallas) on August 23, 2008 at 07:23 PM
Message release the sensor first and then pull the cable forward so you can reach the conector, put some boards in the rear wheel too to make more room, i use the same boards in mine, don't forget the ground wire, good luck!!!
